[GRASS-dev] r.out.gdal2 -> r.out.gdal?
Michael Barton michael.barton at asu.edu
Sat Dec 2 12:45:41 EST 2006
On 12/2/06 3:58 AM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
> What do you mean by a "full" install? GRASS needs GDAL regardless of
> r.{in,out}.gdal.
> You will need GDAL headers and library to build r.out.gdal, and the
> library to run it.
> OTOH, GDAL won't need to be built with GRASS support, so you don't
> need to build GDAL without GRASS, build GDAL, then build it again with
> GRASS (unless you need GDAL to have GRASS support for some other
> reason).
Actually, it appears that I really had two questions. One you've answered.
The other is will GDAL need to be installed for GRASS binaries to work after
it has been built?
Thanks
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
