[GRASS-dev] [bug #5219] (grass) d.vect display=cat works only for layer 1
Martin Landa landa.martin at gmail.com
Mon Dec 4 06:15:52 EST 2006
2006/12/4, Hamish <hamish_nospam at yahoo.com>:
> Martin Landa wrote:
> > > this bug's URL: http://intevation.de/rt/webrt?serial_num=5219
> > It seems you have to specify the llayer parameter too,  e.g.
> > d.erase;d.vect pts2 layer=2 display=shape,cat llayer=2
> > It is really confusing, I am not sure how to solve it. Do you think,
> > would be enough to print a given warning, e.g. "The layer number (2)
> > and layer number for labels (1) are not the same.".
> It would appear to be perfectly legal to display shapes from one layer
> and labels from another. So if this should be mentioned at all, it
> should use G_message and not G_warning? (so --quiet makes it go away)
> At minimum the label section of the d.vect help page needs to clarify
> this.
I agree with you, the similar patch (note: without doc update)?
Best regards, Martin
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20061204/50dde4ba/d_vect_llayer.diff.gz
