[GRASS-dev] [bug #5219] (grass) d.vect display=cat works only for
layer 1
Martin Landa
landa.martin at gmail.com
Mon Dec 4 06:25:11 EST 2006
... oops, I forgot to test DISP_CAT, etc. The updated patch attached.
Martin
2006/12/4, Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2006/12/4, Hamish <hamish_nospam at yahoo.com>:
> > Martin Landa wrote:
> > > > this bug's URL: http://intevation.de/rt/webrt?serial_num=5219
> > > It seems you have to specify the llayer parameter too, e.g.
> > > d.erase;d.vect pts2 layer=2 display=shape,cat llayer=2
> > > It is really confusing, I am not sure how to solve it. Do you think,
> > > would be enough to print a given warning, e.g. "The layer number (2)
> > > and layer number for labels (1) are not the same.".
> > It would appear to be perfectly legal to display shapes from one layer
> > and labels from another. So if this should be mentioned at all, it
> > should use G_message and not G_warning? (so --quiet makes it go away)
> > At minimum the label section of the d.vect help page needs to clarify
> > this.
> I agree with you, the similar patch (note: without doc update)?
> Best regards, Martin
> Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20061204/c2084620/d_vect-llayer-2.diff.gz
