[GRASS-dev] [bug #5373] (grass) Create new location from EPSG code
accpts garbage as code
Request Tracker
grass-bugs at intevation.de
Thu Dec 7 17:07:48 EST 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5373
Subject: Create new location from EPSG code accpts garbage as code
Platform: GNU/Linux/x86
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: 6.2.0
Create new location from EPSG code will accept any garbage as EPSG code and
pass it for location creation. Next message from GRASS will not indicate any
problems (like wrong EPSG code). After GRASS restart (click on OK at popuped
rstart dialog) there is new location "randomnubmer.tmp" with mapset
PERMANENT, but it is not valid mapset (as it should be).
1) If EPSG code can be only number, it's easy to catch user error before
pasing it for processing;
2) There should be some notification to user if creaton of new location has
failed.
-------------------------------------------- Managed by Request Tracker
