[GRASS-dev] Re: winGRASS
Paul Kelly paul-grass at stjohnspoint.co.uk
Thu Dec 14 10:15:09 EST 2006
On Thu, 14 Dec 2006, Moritz Lennert wrote:
>>>> It is in /mingw/share/bison/m4sugar/m4sugar.m4. I don't know why it is
>>>> looking for it in msys ? This causes an error in the compilation of
>>>> libvect and so many consequent errors.
>>> Ah OK. I think I hacked about with that a little bit come to think of it.
>>> Just put it where it's looking for it ;)
>> I'll try as mentioned above. If that doesn't help, I'll move it around.
> It is installed in c:\msys\1.0\share.
> I copied everything to c:\msys\share.
> But I still get the same error. When I try to access /msys from within the
> msys shell window, I also get an error. I actually have to do /c/msys to get
> there. But I just can't find where the path is coded...
Hmm I think when I had the problem it was looking for /usr/share/bison/...
So I don't understand. Must be some installation thing; really don't know.
>> Yes, saw an error on that. Will try to figure out how to change the
>> makefile.
> I haven't really found out how to change this. Currently the Makefile
> contains:
> # some definitions
> SECT = 1
> MANDIR  = $(GISBASE)/man/man$(SECT)
> HTMLDIR = $(GISBASE)/docs/html
> HTML2MAN = GRASS_PERL=${PERL} VERSION_NUMBER=${GRASS_VERSION_NUMBER} sh
> $(GRASS_HOME)/tools/g.html2man/g.html2man
> MANPAGES := $(patsubst $(HTMLDIR)/%.html,$(MANDIR)/%.$(SECT),$(wildcard
> $(HTMLDIR)/*.html))
> default: $(MANDIR) $(MANPAGES)
> $(MANDIR):
>        $(MKDIR) $(MANDIR)
> $(MANDIR)/%.$(SECT): $(HTMLDIR)/%.html
>        $(HTML2MAN) $< $@ $(SECT)
> The problem is in the last line where g.html2man is called. just commenting
> out the last line doesn't seem to work:
You maybe need the line to still start with a Tab, then comment out the
rest? I don't know. But tider probably to just delete
$(MANDIR) $(MANPAGES) after default:
> Other than that I get a running binary which I can launch from within msys.
> Launching it with grass63.bat does not seem to work. I don't get the startup
> screen and I get a message about g.dirsep not being found.
Oops - I forgot to add g.dirseps to the list of modules compiled by
default in general/Makefile. If you just change into the g.dirseps
directory and run make perhaps it will work after that. Remember to check
that you need backslashes in the WINGISBASE path in grass63.bat.
Paul
