[GRASS-dev] change region
Fri Dec 15 07:23:16 EST 2006
Alexander Schulze wrote:
> I define a new location ba EPSG-Code (32648). After this I want to set the extents with
>     g.region n=6681125.59
> and I get the Error Invalid region. If I have only 6 numbers in front of the point, Grass except my changes.
> Could it be a bug?
What does "g.region -p" print?
Try setting the resolution as well; if the resolution is too small,
the number of rows/columns may overflow the range of a 32-bit signed
integer.
