[GRASS-dev] some GRASS source and packaging observations and
questions
William Kyngesburye
woklist at kyngchaos.com
Sat Dec 16 15:39:19 EST 2006
On Dec 16, 2006, at 7:25 AM, Glynn Clements wrote:
>> - bin/scripts - I'm curious if there is a practical reason to
>> separate compiled progs and scripts into bin and scripts folders?
>> Maybe some have the scripts folder name hardcoded in them for some
>> reason, or maybe in the GUI?
>> Basically they are all executables, and it adds another path item
>> needed in the PATH env. (And I need to deal with a possible/rare
>> case-sensitivity problem in a Mac app package between 'scripts' and
>> 'Scripts'.)
> Until recently, there wasn't any compelling reason for having separate
> directories.
> However, Paul Kelly recently figured out a simple and effective way to
> make Bourne-shell scripts work natively on Windows: for each script,
> install a corresponding .bat file (in the bin directory) which
> explicitly invokes the shell on the script (in the scripts directory).
> In that situation, it makes sense to have separate directories, as the
> scripts are essentially data files (for use by the shell interpreter)
> rather than executables in their own right. Only the bin directory is
> added to the path.
I noticed the discusion on that, just didn't pay attention to it ^_^
There are explicit references to scripts in init.sh - for checking
the availability of the GUIs before trying to start them. I guess
that means I'll leave scripts in Scripts for now and my new OSX
GRASS.app startup won't run on a case-sensitive Mac file-system.
But, running anything on a Mac case-sensitive file system in
generally not recommended. Heck, using a case-sensitive HFS+ or UFS
on OSX at all is not recommended.
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed
robot?
[Marvin] You think you have problems? What are you supposed to do
if you ARE a maniacally depressed robot? No, don't try and answer,
I'm 50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
"Those people who most want to rule people are, ipso-facto, those
least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
