[GRASS-dev] OSX packages
Mon Dec 18 02:46:44 EST 2006
AFAIK you can drop "GD" from frameworks. It isn't used anymore. Also, it
would be nice if the AllFrameworks.dmg installer allowed you to deselect
packages in the Customize menu.
Also I am not sure if it is worth mentioning GLw/r3.showdspf at all in
the README as it isn't switched- it requires a Makefile hack to enable.
Hamish
