[GRASS-dev] Patch for QGIS ticket 448 (cannot start database driver)
Radim Blazek radim.blazek at gmail.com
Mon Dec 18 04:39:46 EST 2006
QGIS is using GRASS HEAD but it should use stable release
of GRAS IMO. The patch should be applied also to 6.2 branch
because it is bugfix.
Do you say that 6.2.1 is useless on Windows?
Radim
On 12/17/06, Markus Neteler <neteler at itc.it> wrote:
> To GRASS 6.3-CVS.
> As far as I understand, QGIS uses GRASS from CVS to prepare the
> winGRASS extension. 6.2.1 is completely lagging behind concerning
> Windows fixes.
> I think that it is fine like that.
> Markus
> On Sun, Dec 17, 2006 at 06:50:40PM +0100, Paolo Cavallini wrote:
> > -----BEGIN PGP SIGNED MESSAGE-----
> > Hash: SHA1
> > to which branch?
> > it would be good to have in 6.2.1(.1?), so coming qgis will have it by
> > default?
> > pc
> > Markus Neteler ha scritto:
> > > On Sun, Dec 17, 2006 at 05:53:25PM +0100, Radim Blazek wrote:
> > >> Here is the patch for https://svn.qgis.org/trac/ticket/448
> > >> (grass/lib/db/dbmi_client/start.c).
> > >> Unfortunately if QGIS is compiled without stdin/stdout and then run
> > >> from batch, cmd.exe or MSYS shell, it will open command window for a
> > >> while always when a new GRASS database driver is started.
> > >> Radim
> > > Patch applied.
> > > Markus
> > > _______________________________________________
> > > grass-dev mailing list
> > > grass-dev at grass.itc.it
> > > http://grass.itc.it/mailman/listinfo/grass-dev
> > Paolo Cavallini
> > email+jabber: cavallini at faunalia.it
> > www.faunalia.it
> > Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy   Tel: (+39)348-3801953
> > -----BEGIN PGP SIGNATURE-----
> > Version: GnuPG v1.4.6 (GNU/Linux)
> > Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> > iD8DBQFFhYNw/NedwLUzIr4RAlN1AJwJL/5AutK6VRdpR+FkAku2X7t8qwCeM+ny
> > rq9Os2h1ZScONhYwbVRyoIA=
> > =a6p9
> > -----END PGP SIGNATURE-----
> Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
> ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18        -       38050 Povo (Trento), Italy
