[GRASS-dev] Patch for QGIS ticket 448 (cannot start database
driver)
Markus Neteler
neteler at itc.it
Mon Dec 18 05:57:17 EST 2006
On Mon, Dec 18, 2006 at 10:39:46AM +0100, Radim Blazek wrote:
> QGIS is using GRASS HEAD but it should use stable release
> of GRAS IMO. The patch should be applied also to 6.2 branch
> because it is bugfix.
Done.
> Do you say that 6.2.1 is useless on Windows?
Yes, I think so (at least for the native built).
6.3-CVS is way more advanced.
Markus
> Radim
> On 12/17/06, Markus Neteler <neteler at itc.it> wrote:
> >To GRASS 6.3-CVS.
> >As far as I understand, QGIS uses GRASS from CVS to prepare the
> >winGRASS extension. 6.2.1 is completely lagging behind concerning
> >Windows fixes.
> >I think that it is fine like that.
> >Markus
> >On Sun, Dec 17, 2006 at 06:50:40PM +0100, Paolo Cavallini wrote:
> >> -----BEGIN PGP SIGNED MESSAGE-----
> >> Hash: SHA1
> >> to which branch?
> >> it would be good to have in 6.2.1(.1?), so coming qgis will have it by
> >> default?
> >> pc
> >> Markus Neteler ha scritto:
> >> > On Sun, Dec 17, 2006 at 05:53:25PM +0100, Radim Blazek wrote:
> >> >> Here is the patch for https://svn.qgis.org/trac/ticket/448
> >> >> (grass/lib/db/dbmi_client/start.c).
> >> >> Unfortunately if QGIS is compiled without stdin/stdout and then run
> >> >> from batch, cmd.exe or MSYS shell, it will open command window for a
> >> >> while always when a new GRASS database driver is started.
> >> >> Radim
> >> > Patch applied.
> >> > Markus
> >> > _______________________________________________
> >> > grass-dev mailing list
> >> > grass-dev at grass.itc.it
> >> > http://grass.itc.it/mailman/listinfo/grass-dev
> >> Paolo Cavallini
> >> email+jabber: cavallini at faunalia.it
> >> www.faunalia.it
> >> Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
> >> -----BEGIN PGP SIGNATURE-----
> >> Version: GnuPG v1.4.6 (GNU/Linux)
> >> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> >> iD8DBQFFhYNw/NedwLUzIr4RAlN1AJwJL/5AutK6VRdpR+FkAku2X7t8qwCeM+ny
> >> rq9Os2h1ZScONhYwbVRyoIA=
> >> =a6p9
> >> -----END PGP SIGNATURE-----
> >Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
> >ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
> >MPBA - Predictive Models for Biol. & Environ. Data Analysis
> >Via Sommarive, 18 - 38050 Povo (Trento), Italy
