[GRASS-dev] Re: winGRASS
Moritz Lennert
mlennert at club.worldonline.be
Mon Dec 18 04:49:44 EST 2006
On Fri, December 15, 2006 23:50, Moritz Lennert wrote:
> On Fri, December 15, 2006 18:01, Paul Kelly wrote:
>> On Fri, 15 Dec 2006, Moritz Lennert wrote:
>>> Next step: make install
>>> - doesn't install the grass63.bat file in bin
>>> - when I copy grass63.bat to c:\grass\bin and modify it so that
>>> set WINGISBASE=c:\grass\grass-6.3.cvs
>>> I get error in startup script: "can't read "env(GISBASE)": no such
>>> variable while executing "source $env(GISBASE)/etc/gtcltk/gmsg.tcl"
>>> (file
>>> "c:\grass\grass-6.3.cvs\etc\gis_set.tcl" line 29)
>> Possibly that something goes wrong in init.bat because the demolocation
>> directory doesn't get copied across during "make install"? I had been
>> using the .grassrc63 file in there as a temporary GISRC file so
>> g.dirseps
>> would work. Need to find a clean solution to this - all it needs is a
>> temporary file; it is fairly meaningless really. This ties in nicely
>> with
>> what Michael is looking at wrt a temporary GISRC file to make g.proj
>> run!
>> If you copy across "demolocation/.grassrc63" to the install directory
>> does
>> it work? If so, that confirms the problem and we need to look at a more
>> elegant solution with regard to the temporary GISRC files.
Yes, this works. Now I can startup grass without msys !
Now, to go on:
- I had hoped that Radim's patch for dbmi_client
(http://grass.itc.it/pipermail/grass5/2006-December/028118.html) might
solve the issue I've had with the db protocol errors, but apparently this
is not the case. When I push the 'show the attribute columns' in a vector
panel, I still get
Displaying column types/names for database connection of layer 1:
dbmi: Protocol error
Cannot open table <streams>
and a 'v.db.select' on the same map gives me:
'vector/streams' was found in more mapsets (also found in user1).
Cannot open select cursor
Radim, as you have been working on this these days, do you have an idea
what might be wrong ?
- I noticed that I can close the com.exe window and still continue using
grass. Is there any reason to keep this open ? If not, is there a way to
close it automatically ? Just a question of not multiplying unnecessary
windows.
- Help does not work. In individual command windows, the help button is
desactivated. In layer panels in the main GIS Manager window, when I push
the help button, I get:
child process exited abnormally
while executing
"exec -- g.manual d.vect >& NUL:"
("eval" body line 1)
invoked from within
"eval [list exec -- $cmd] $args >& $devnull"
(procedure "run" line 8)
invoked from within
"run g.manual d.vect"
("uplevel" body line 1)
invoked from within
"uplevel \#0 $cmd"
(procedure "Button::_release" line 18)
invoked from within
"Button::_release .mainframe.frame.pw1.f1.frame.sw.sf.frame.fr.name.e"
(command bound to event)
