[GRASS-dev] [bug #5396] (grass) hermannskogel datum parameters for Slovakia
Request Tracker grass-bugs at intevation.de
Mon Dec 18 07:40:30 EST 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5396
Subject: hermannskogel  datum parameters for Slovakia
Platform: GNU/Linux/x86
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
Hermannskogel datum parameters for Slovakia (Krovak projection) are wrong. The estimated error for these parameters is about 120-130 m.
Unless proper parameters are available I suggest to use parameters for Czech republic which give acceptable results with 1-3 meter error.
The item for Slovakia should be removed from menu and item for Czech republic (1.) could be extended to include also Slovakia.
The evaluation was done using local cartographic tools (Samuel for ArcView and Dattra).
-------------------------------------------- Managed by Request Tracker
