[GRASS-dev] [bug #5396] (grass) hermannskogel datum parameters for Slovakia
Martin Landa landa.martin at gmail.com
Tue Dec 19 04:32:13 EST 2006
Hi all,
after discussion in the CzechoSlovak mailing list I fixed this bug,
there is common geodetic datum for Czech Republic and Slovakia.
hermannskogel "towgs84=570.8,85.7,462.8,4.998,1.587,5.261,3.56" "Czech
Republic/Slovakia" " "
Best, Martin
2006/12/18, Request Tracker <grass-bugs at intevation.de>:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=5396
> Subject: hermannskogel  datum parameters for Slovakia
> Platform: GNU/Linux/x86
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> Hermannskogel datum parameters for Slovakia (Krovak projection) are wrong. The estimated error for these parameters is about 120-130 m.
> Unless proper parameters are available I suggest to use parameters for Czech republic which give acceptable results with 1-3 meter error.
> The item for Slovakia should be removed from menu and item for Czech republic (1.) could be extended to include also Slovakia.
> The evaluation was done using local cartographic tools (Samuel for ArcView and Dattra).
> -------------------------------------------- Managed by Request Tracker
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
