[GRASS-dev] [bug #5396] (grass) hermannskogel datum parameters
for Slovakia
Markus Neteler
neteler at itc.it
Tue Dec 19 04:42:57 EST 2006
Hi Martin,
should this also go into 6.2-CVS?
Markus
On Tue, Dec 19, 2006 at 10:32:13AM +0100, Martin Landa wrote:
> Hi all,
> after discussion in the CzechoSlovak mailing list I fixed this bug,
> there is common geodetic datum for Czech Republic and Slovakia.
> hermannskogel "towgs84=570.8,85.7,462.8,4.998,1.587,5.261,3.56" "Czech
> Republic/Slovakia" " "
> Best, Martin
> 2006/12/18, Request Tracker <grass-bugs at intevation.de>:
> >this bug's URL: http://intevation.de/rt/webrt?serial_num=5396
> >Subject: hermannskogel datum parameters for Slovakia
> >Platform: GNU/Linux/x86
> >grass obtained from: Trento Italy site
> >grass binary for platform: Compiled from Sources
> >Hermannskogel datum parameters for Slovakia (Krovak projection) are wrong.
> >The estimated error for these parameters is about 120-130 m.
> >Unless proper parameters are available I suggest to use parameters for
> >Czech republic which give acceptable results with 1-3 meter error.
> >The item for Slovakia should be removed from menu and item for Czech
> >republic (1.) could be extended to include also Slovakia.
> >The evaluation was done using local cartographic tools (Samuel for ArcView
> >and Dattra).
> >-------------------------------------------- Managed by Request Tracker
> >_______________________________________________
> >grass-dev mailing list
> >grass-dev at grass.itc.it
> >http://grass.itc.it/mailman/listinfo/grass-dev
> Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
