[GRASS-dev] New 'output' parameter in r.colors
Moritz Lennert
mlennert at club.worldonline.be
Mon Dec 18 09:35:27 EST 2006
On 18/12/06 15:18, Patton, Eric wrote:
> Hi,
> I just noticed today that there's a new 'output' parameter, which
> seems to replace the old 'map' parameter in r.colors. Specifically, I
> noticed it when several of my scripts broke due to the new parameter
> name. Does anyone know the rationale for this change?
> Isn't it usually the case with raster modules that 'input' and
> 'output' params are used only when a new raster is being written,
> else 'map' parameter is used?
> Sorry if I missed the thread on this, or if it's already been
> documented elsewhere.
I don't see an output parameter... ? It actually wouldn't be logical as
the module does not provide any 'output'.
Are you sure you are looking at r.colors ?
Moritz
