[GRASS-dev] change region
Mon Dec 18 09:48:00 EST 2006
Hamish wrote:
> > I define a new location ba EPSG-Code (32648). After this I want to set
> > the extents with
> >     g.region n=6681125.59
> > and I get the Error Invalid region. If I have only 6 numbers in front
> > of the point, Grass except my changes. Could it be a bug?
> It works for me in GRASS 6.2.1. (make a new location from the GUI
> startup menu using EPSG number, then "g.region n=6681125.59".
> Are you sure it isn't defined as a Lat/Lon location instead of UTM zone 48N?
> what if you create the region using UTM instead of EPSG code? (create by
> Projection Values)
FWIW, he replied privately, indicating that setting the resolution
solved the problem.
