[GRASS-dev] Missing projections
Glynn Clements
glynn at gclements.plus.com
Mon Dec 18 13:58:48 EST 2006
The following projections are listed by "proj -lp" but don't have
entries in proj-parms.table:
geos : Geostationary Satellite View
lcca : Lambert Conformal Conic Alternative
sterea : Oblique Stereographic Alternative
vitk1 : Vitkovsky I
Can anyone provide the necessary parameter information, i.e. which
PROJ parameters they accept, and what (if any) default value should be
used?
FWIW, the "proj -lP" output for these says:
Azi, Sph&Ell
h=
Conic, Sph&Ell
lat_0=
Azimuthal, Sph&Ell
vitk1 : Vitkovsky I
Conic, Sph
lat_1= and lat_2=
BTW, it turns out that vitk1 was present in the old geo.h/geo_init.c,
but with no parameters. The other three weren't listed at all.
