[GRASS-dev] Re: [GRASS-user] problems using r.proj with large
data set
Dylan Beaudette
dylan.beaudette at gmail.com
Tue Dec 19 15:08:03 EST 2006
> > > > Assuming that it works out okay, I'll probably end up merging
> > > > r.proj.seg into r.proj, with the macro handling the details of
> > > > whether to read from a tile cache (large maps) or from a single block
> > > > of memory (small maps).
> > > This makes sense. For small maps is it much faster to not use the
> > > cache?
> > I haven't performed timings; to be of much use, they would need to be
> > done with "real-world" cases.
> > As it stands, even if you made the cache large enough to hold the
> > entire map, it would currently get written out to a temporary file
> > then read back in on demand.
> > There's bound to be some overhead to using an extra level of
> > indirection, but it's probably trivial compared to the projection
> > calculations (and particularly compared to bicubic interpolation).
> > One of the next things which needs to be done to r.proj.seg is to add
> > an option to set the cache size. Once that's done, I'll look into
> > trapping the case where the cache can hold the entire map, and
> > eliminate the temporary file in that situation.
> I've done that; some (not exactly representative) results reprojecting
> GTOPO30 to spearfish (30m, 634 cols x 477 rows):
> $ r.proj input=w140n90 location=global mapset=glynn output=proj
> method=nearest
> real 0m2.971s
> user 0m2.922s
> sys 0m0.023s
> $ r.proj.seg memory=100 input=w140n90 location=global mapset=glynn
> output=proj method=nearest
> real 0m2.929s
> user 0m2.891s
> sys 0m0.018s
> method=bilinear
> real 0m3.419s
> user 0m3.280s
> sys 0m0.106s
> $ r.proj.seg input=w140n90 location=global mapset=glynn output=proj
> method=bilinear memory=100
> real 0m3.461s
> user 0m3.346s
> sys 0m0.088s
> method=cubic
> real 0m3.877s
> user 0m3.731s
> sys 0m0.111s
> output=proj method=cubic
> real 0m4.169s
> user 0m4.058s
> sys 0m0.093s
> The speed of r.proj.seg relative to r.proj ranges from ~1.4% faster
> (nearest) to ~7.5% slower (bicubic). If those results hold up for
> representative data, r.proj.seg can replace r.proj.
i had similar tming results for my data:
Input Projection Parameters: +proj=longlat +no_defs +a=6378137
+rf=298.257222101 +towgs84=0.000,0.000,0.000
Input Unit Factor: 1
Output Projection Parameters: +proj=aea +lat_1=20 +lat_2=60 +lat_0=40
+lon_0=-96 +x_0=0 +y_0=0 +no_defs +a=6378137 +rf=298.257222101
Output Unit Factor: 1
Input:
Cols: 3500 (3500)
Rows: 2500 (2500)
North: 40.000000 (40.000000)
South: 37.500000 (37.500000)
West: -123.000000 (-123.000000)
East: -119.500000 (-119.500000)
ew-res: 0.001000
ns-res: 0.001000
Output:
Cols: 3934 (7340)
Rows: 3994 (13894)
North: 306990.000000 (560610.000000)
South: -52470.000000 (-689850.000000)
West: -2223720.000000 (-2236860.000000)
East: -1869660.000000 (-1576260.000000)
ew-res: 90.000000
ns-res: 90.000000
---------------- results --------------------
r.proj:
real 0m32.558s
user 0m31.690s
sys 0m0.336s
r.proj.seg:
real 0m34.995s
user 0m32.978s
sys 0m0.952s
the output from r.proj and r.proj.seg give about 99.99% identical results. I
have attached the output from r.report run on the difference between the two
maps.
it looks like a couple of us have confirmed these results. Replacing r.proj
with the new r.proj.seg seems like a good idea:
1. fixes the nasty bilinear bug (yikes)
2. handles very large files (great!)
great job glynn!
Cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
| RASTER MAP CATEGORY REPORT |
| north: -63025.00495929 east: -1909837.87169447 |
|REGION south: -98868.38404437 west: -1936490.64075773 |
| res: 29.99445949 res: 30.01437958 |
|MASK:none |
|MAP: (untitled) (e.diff in PERMANENT) |
| Category Information | cell|
| #|description | count|
| 0-1.780694|from to . . . . . . . . . . . . . . . . . . . | 642694|
| 1.780694-3.561387|from to . . . . . . . . . . . . . . . . . . . | 2|
| 3.561387-5.342081|from to . . . . . . . . . . . . . . . . . . . | 2|
| 5.342081-7.122775|from to . . . . . . . . . . . . . . . . . . . | 2|
| 7.122775-8.903469|from to . . . . . . . . . . . . . . . . . . . | 2|
| 8.903469-10.684162|from to . . . . . . . . . . . . . . . . . . . | 2|
| 10.684162-12.464856|from to . . . . . . . . . . . . . . . . . . . | 1|
| 17.806937-19.587631|from to . . . . . . . . . . . . . . . . . . . | 1|
| 19.587631-21.368325|from to . . . . . . . . . . . . . . . . . . . | 2|
| 28.4911-30.271794|from to . . . . . . . . . . . . . . . . . . . | 1|
| 51.640119-53.420812|from to . . . . . . . . . . . . . . . . . . . | 1|
| 60.543587-62.324281|from to . . . . . . . . . . . . . . . . . . . | 1|
| 73.008443-74.789137|from to . . . . . . . . . . . . . . . . . . . | 1|
|156.701049-158.481743|from to . . . . . . . . . . . . . . . . . . . | 1|
| 259.981286-261.76198|from to . . . . . . . . . . . . . . . . . . . | 1|
|452.296211-454.076904|from to . . . . . . . . . . . . . . . . . . . | 1|
| *|no data. . . . . . . . . . . . . . . . . . . . | 418445|
|TOTAL |1061160|
