[GRASS-dev] Re: [GRASS-user] problems using r.proj with large
data set
Glynn Clements
glynn at gclements.plus.com
Tue Dec 19 17:16:18 EST 2006
Dylan Beaudette wrote:
> the output from r.proj and r.proj.seg give about 99.99% identical results. I
> have attached the output from r.report run on the difference between the two
> maps.
Odd. There shouldn't be *any* difference (other than the fact that
r.proj.seg will tend to produce some nulls where r.proj produces
non-null values). The difference map should have min=max=0, i.e.
wherever both programs produce non-null values, they should be
identical.
AFAICT, there shouldn't even be any rounding-error differences; the
actual interpolation expressions are essentially identical.
Can you figure out a way to reproduce this with readily-available data
(or even synthetic data)?
