[GRASS-dev] Missing projections
Morten Hulden
morten at untamo.net
Wed Dec 20 03:19:41 EST 2006
Glynn Clements wrote:
> Maciej Sieczka wrote:
>>> The following projections are listed by "proj -lp" but don't have
>>> entries in proj-parms.table:
>>> geos : Geostationary Satellite View
>>> lcca : Lambert Conformal Conic Alternative
>>> sterea : Oblique Stereographic Alternative
>>> vitk1 : Vitkovsky I
>>> Can anyone provide the necessary parameter information, i.e. which
>>> PROJ parameters they accept, and what (if any) default value should be
>>> used?
geos projection needs only longitude and height (but doesn't say no to
kfact). Latitude seems to be fixed at 0 degrees. In reality most
geostationary satellites seem to deviate a little from 0 degrees. Pity,
because then geos can't be used (but nsper projection can). Height is
usually about 35700-35800 km.
http://www.n2yo.com
GEOS:HEIGH=ask,35800000.0;LON0=ask,20.0
> I'm not sure where the LON0 default comes from; of 121 projections,
> 119 accept LON0 (UPS and UTM are the exceptions), and 100 of those
> have 20 as the default.
I can explain that. I had a test map centered around lon 20, lat 55 when
I added the projections back in 1998. I used 20/55 as default for most.
May not please everyone to have Europe as default but was better than
making up something for which I did not have a map and could not test.
And using "neutral" 0/0 was not valid for many projections so I chose to
use a real world example as default.
Morten
