[GRASS5] [bug #4049] (grass) d.m: dozens of d.mon zombies
Michael Barton
michael.barton at asu.edu
Wed Feb 1 01:49:27 EST 2006
Glynn,
I implemented these suggestions and it seems to help a lot. Most of the open
"|d.mon -L" calls were left over from the old d.m and I got rid of them.
However, a few did leave these open. I've fixed these. I'm also using the -s
flag and MONITOR_OVERRIDE.
These seem to have nearly eliminated the unable to fork child process
errors. It's probably still breakable, but considerably more difficult to do
so.
Thanks much.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Tue, 31 Jan 2006 19:00:11 +0000
> To: Request Tracker <grass-bugs at intevation.de>
> Cc: <grass5 at grass.itc.it>, Michael Barton <michael.barton at asu.edu>
> Subject: Re: [GRASS5] [bug #4049] (grass) d.m: dozens of d.mon zombies
> Request Tracker wrote:
>> this bug's URL: http://intevation.de/rt/webrt?serial_num=4049
>> Subject: d.m: dozens of d.mon zombies
>> Platform: GNU/Linux/x86
>> grass obtained from: Trento Italy site
>> grass binary for platform: Compiled from Sources
>> GRASS Version: CVS 2005.01.27
>> Uisng d.m leads to lots of zombi d.mon processes.
>> 1. grass61 -text
>> 2. d.m
>> 3. ps -A | grep d.mon
>> 19313 pts/2 00:00:00 d.mon <defunct>
>> 4. press "x1" in d.m, or redraw, zoom, pan
>> 5. ps -A | grep d.mon
>> 19340 pts/2 00:00:00 d.mon <defunct>
>> ... and so on.
>> By the end of Grass session there are dozens of d.mon zombies. Quiting d.m
>> colses them all.
> FWIW, I also see lots of g.region zombies.
> AFAICT, it's due to the use of "open", e.g.:
> gm.tcl:298: if ![catch {open "|d.mon -L" r} input] {
> gm.tcl:319: if ![catch {open "|d.mon -L" r} input] {
> gm.tcl:385: if ![catch {open "|d.mon -L" r} input] {
> gm.tcl:611: if ![catch {open "|d.mon -L" r} input] {
> mapcanvas.tcl:233: if ![catch {open "|g.region -g" r} input] {
> mapcanvas.tcl:283: if ![catch {open "|d.mon -L" r} input] {
> mapcanvas.tcl:436: if ![catch {open "|g.region -g" r} input] {
> mapcanvas.tcl:599: if ![catch {open "|g.region -g" r} input] {
> mapcanvas.tcl:962: if ![catch {open "|g.region -g" r} input] {
> vector.tcl:548: if ![catch {open "|d.mon -L" r} input] {
> I can't find a single case which calls "close $input" once the stream
> is finished with. I suspect that wish won't actually wait() for the
> process until you call close, hence the accumulation of zombies.
> BTW, I suspect that most of those "d.mon -L" commands are unnecessary.
> You should be unconditionally starting the monitor before drawing
> anything and unconditionally stopping it once you're done.
> Also, none of the "d.mon start=PNG" commands have the -s switch; this
> will interfere with the user's choice of selected monitor. Use -s and
> $MONITOR_OVERRIDE instead of modifying $GISRC.
