[GRASS5] Re: [GRASSLIST:10124] RE: updates to gism2 - Feb2, 2006
Michael Barton michael.barton at asu.edu
Fri Feb 3 13:58:55 EST 2006
Chris and Eric,
I fixed these issues in the cvs and the copy on my website now.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
Date: Thu, 2 Feb 2006 09:59:06 -0500
To: "Patton, Eric" <epatton at nrcan.gc.ca>
Cc: 'Michael Barton ' <michael.barton at asu.edu>, "'owner-GRASSLIST at baylor.edu
'" <owner-GRASSLIST at baylor.edu>, 'grass developers list '
<grass5 at grass.itc.it>, 'Multiple recipients of list ' <GRASSLIST at baylor.edu>
Subject: Re: [GRASSLIST:10124] RE: updates to gism2 - Feb2, 2006
Hi again,
Thank you again for the most recent fixes!
I can verify Eric's errors 1-3 regarding workspace resource files, again
working on MacOSX. The only notes I'd add include the following:
> 1) Clicking the 'Open existing workspace file' button opens a 'Save File'
> dialog box. Shouldn't this be an Open File box?
This seems only to be a dialog box *title* problem: the button does actually
open (and not save) a resource file.
> 2) Trying to open a Workspace file through File/Groups/Open menu gives an
> error. I've attached it as 'Open Workspace Error.log'.
> 3) I created a workspace file from scratch. I added 2 rasters to the gis
> manager, then clicked File/Groups/Save as which gave the error message
> attached in 'Save_Workspace_Error.log'. I am able to save the workspace
> using the GUI button on the display manager, however. The saved workspace
> file re-opens normally.
While the GUI buttons related to resource files all work for me, the only
command under the menus (File>Groups> ...) that seems to work is "Close". By
the same token, the only keyboard shortcut that works in this menu is ctrl-W
for "Close."
Chris
On Feb 2, 2006, at 9:29 AM, Patton, Eric wrote:
> Hi Michael,
> I downloaded gism_rc1_20060201 this morning and gave it a try; thanks for
> the updates! We're definitely getting closer here.
> Some observations:
> 4) Most Grass commands typed into the run dialog don't seem to do anything.
> I only tried a few commands, i.e. g.region -p, d.rast map=rastername don't
> run, but r.composite does. Do only a subset of Grass programs run in this
> dialog?
> 5) Once a code block is pasted into the 'run' dialog, clicking the 'save'
> button produces an error message, which is attached as
> Command_Save_Error.log.
> HTH,
> ~ Eric.
> -----Original Message-----
> From: owner-GRASSLIST at baylor.edu
> To: grass developers list; Multiple recipients of list
> Sent: 2/1/2006 7:55 PM
> Subject: [GRASSLIST:10120] updates to gism2
> I posted to my web site and Markus helped me commit to the cvs a set of
> updates to the GIS Manager 2 GUI that addresses some of the issues that
> popped up over the last couple days.
> I noticed that I cannot produce text overlays on my Mac using d.text or
> d.text.freetype. I'd like to know if this is the same under other OS's
> also. d.label does work, however.
> d.text.freetype has not worked on the Mac since the upgrade to OSX10.4,
> but d.text did work. So I need to know if this is a Mac issue or
> everyone has the same lack of text under the new TclTk canvas displays.
> If the latter, I can add a TclTk text module that will do essentially
> the same thing as d.text.freetype and should work on all systems.
> Michael
> USA
> <http://www.public.asu.edu/~cmbarton>
> <Open_Workspace_Error.log>
> <Save_Workspace_Error.log>
> <Command_Save_Error.log>
C. H. Roosevelt
Archaeology Department
Boston University
675 Commonwealth Avenue
Boston, MA, 02215-1406
Tel: (617) 358-1652 (direct)
Tel: (617) 353-3415 (main office)
Fax: (617) 353-6800
E-mail: chr at bu.edu
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20060203/a10f7b41/attachment.html
