[GRASS5] [bug #4069] (grass) r.carve: output identical to input and segfault when using points=
Maciek Sieczka via RT
grass-bugs at intevation.de
Tue Feb 7 12:07:02 EST 2006
I have just tried with the same input DEM but very simple, single vector line
indicating input streamline. I made sure it doesn't exceed the input DEM
extent this time.
$ r.carve rast=nnbathy_D_no vect=carveit output=nnbathy_D_no_carved
points=nnbathy_D_no_carved_pkt width=10.000000 depth=0.1 -n Reading raster file...
100%
Processing lines...
Writing raster file... done.
Building topology ...
0 primitives registered
0 areas built
0 isles built
Attaching islands:
Attaching centroids: Topology was built.
Number of nodes : 0
Number of primitives: 0
Number of points : 0
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
r.carve complete. r.carve -n rast="nnbathy_D_no" vect="carveit"
output="nnbathy_D_no_carved" points="nnbathy_D_no_carved_pkt" width=10.000000
depth=0.1
No segfault this time.
Still, the output DEM is _identical_ to input DEM. And the ouput points= has 0
geometry.
No good. Any chances it will be fixed in close future?
Maciek
-------------------------------------------- Managed by Request Tracker
