[GRASS5] [bug #4044] (grass) v.to.db: manual suggests 'type=area', however 'Error: value <area> out of range'
Markus Neteler
neteler at itc.it
Tue Feb 7 16:46:34 EST 2006
On Mon, Feb 06, 2006 at 10:18:44PM +0100, Maciek Sieczka via RT wrote:
> Sorry, I'm to tired to write anything. It's a bite late here in Poland :-6 and
> |(. I meant to write:
> Is type=area presence in the v.to.db manual a typo (I can fix it then) or is
> type=area supposed to be supported indeed (using it gives Error: value <area>
> out of range for parameter <type>), thus it's a bug? And why type=area not
> supported if so?
Maybe Radim knows the answer?
Markus
