[GRASS5] r.mapcalc and d.what.rast bug
Markus Neteler
neteler at itc.it
Wed Feb 8 17:16:30 EST 2006
On Fri, Feb 03, 2006 at 10:39:04AM +0100, Jaro Hofierka wrote:
> BTW, I tried the following example using r.mapcalc:
> >r.mapcalc aa = "tan(90)"
> >d.rast aa
> >GRASS 6.1.cvs (mh):~ > d.what.rast
> >Buttons
> > Left: what's here
> > Right: quit
> > -436846.66875(E) -1187521.35625(N)
> > aa in jaro2, quant (Null)
> > aa in jaro2, actual (16331778728383844.000000)
> To me, both results are incorrect (Null) and (16331778728383844.000000).
> At least, the calculation should be refused, or cells filled with UNDEF.
> Jaro
Jaro, I am experienting the same: either r.mapcalc is wrong or
d.what.rast. Can you check if this also happens inside the map?
Markus
