[GRASS5] [bug #3876] (grass) g.proj: proj4= fails, wkt= works partialy
Maciek Sieczka via RT
grass-bugs at intevation.de
Thu Feb 9 06:20:34 EST 2006
Another update:
Using newer Grass 61 (CVS 2006-02-07) and newer GDAL (CVS 2006-02-09) the
error is different. No longer xy location is created, but a latlong (which is
still not what should be). Read below.
### Creating a location from EPSG code 2180 I get a latlong on WGS84:
$ g.proj -p
-PROJ_INFO-------------------------------------------------
proj : ll
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : degree
units : degrees
meters : 1.0
### While I expect (and used to get always before) a tmerc on GRS80, see:
$ epsg_tr.py -proj4 2180
# ETRS89 / Poland CS92
<2180> +proj=tmerc +lat_0=0 +lon_0=19 +k=0.999300 +x_0=500000 +y_0=-5300000
+ellps=GRS80 +units=m +no_defs <>
Maciek
-------------------------------------------- Managed by Request Tracker
