[GRASS5] [bug #3876] (grass) g.proj: proj4= fails, wkt= works partialy
Markus Neteler
neteler at itc.it
Thu Feb 9 12:42:25 EST 2006
Great, also r.in.gdal works again (detection of data set
projection).
Thanks!
Markus
On Thu, Feb 09, 2006 at 11:20:26AM -0600, Huidae Cho wrote:
> I've committed some bug fixes, so could you test new gproj library and related
> modules?
> Thanks
> Huidae Cho
> On Thu, Feb 09, 2006 at 06:07:19PM +0100, Markus Neteler wrote:
> > Thanks, Huidae,
> > I was trying the same but missed the second one.
> > Now it works.
> > Finally (?) r.in.gdal suffers from the same problem.
> > Any ideas also there?
> > thanks
> > Markus
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
