[GRASS5] [bug #4075] (grass) grass and postgis issue
Request Tracker
grass-bugs at intevation.de
Thu Feb 9 14:11:13 EST 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4075
Subject: grass and postgis issue
Platform: Mac OSX
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: cvs 2006
I am working with postgis tables and GRASS and have found what may be a bug.
If I try and read a postgis table (with geometry columns and spatial indexing into GRASS, I get a new
vector but the associated postgis table has no geometry or spatial indexing. For exmaple:
postgis output from Tyler Ms postgis example in "Web Mapping":
project1=# \d countyp020
Table "public.countyp020"
Column | Type | Modifiers
gid | integer | not null default nextval('countyp020_gid_seq'::regclass)
area | double precision |
perimeter | double precision |
countyp020 | bigint |
state | character varying(2) |
county | character varying(50) |
fips | character varying(5) |
state_fips | character varying(2) |
square_mil | double precision |
the_geom | geometry |
Indexes:
"countyp020_pkey" PRIMARY KEY, btree (gid)
"idx_countyp020_geo" gist (the_geom)
"idx_countyp020_gid" btree (gid)
Check constraints:
"enforce_dims_the_geom" CHECK (ndims(the_geom) = 2)
"enforce_geotype_the_geom" CHECK (geometrytype(the_geom) = 'MULTIPOLYGON'::text OR
the_geom IS NULL)
"enforce_srid_the_geom" CHECK (srid(the_geom) = -1)
However, reading the table back into GRASS with either pgsql2shp, then v.in.ogr on the shapefile, or
directly into GRASS with v.in.ogr on the postgis table, results in a new postgis table that looks like
this:
project1=# \d countyp020_postgis
Table "public.countyp020_postgis"
cat | integer |
gid | integer |
countyp020 | integer |
state | character varying(255) |
county | character varying(255) |
fips | character varying(255) |
state_fips | character varying(255) |
Indexes:
"countyp020_postgis_cat" UNIQUE, btree (cat)
or:
project1=# \d countyp020_grass
Table "public.countyp020_grass"
cat | integer |
countyp020 | double precision |
Indexes:
"countyp020_grass_cat" UNIQUE, btree (cat)
Notice the lack of geometry and idexes in both posgis tables. Also, the difference in type lengths
(character 5 vs 250 for fips).
Additionally, if I add the geometry and idexing in posgis (once it has been read into GRASS and is
therefor connected to the GRASS vector with bd.connect, and then try and copy or rename the vector
with g.copy or g.rename, I get the following error:
> g.rename vect=mn_btvegpt_byspp,mn_btvegpt
RENAME [mn_btvegpt_byspp] to [mn_btvegpt]
WARNING: pg driver: column 'the_geometry', type 16651 is not supported
-------------------------------------------- Managed by Request Tracker
