[GRASS5] Directed Graph Lib Headers (dglib)
Radim Blazek
radim.blazek at gmail.com
Fri Feb 10 09:42:06 EST 2006
On 2/9/06, Glynn Clements <glynn at gclements.plus.com> wrote:
> Radim Blazek wrote:
> > This applies to all header files. We decided to move all GRASS
> > header files to include/grass so that they can be installed on system
> > (e.g. in /usr/local/include) without conflicts.
> > Modules and especially independent applications using GRASS libraries
> > (GDAL/OGR, QGIS) should include grass/xxx.h instead of xxx.h.
> I've committed a change to use <grass/xxx.h> throughout.
Thanks, however include/xxx.h is still used in QGIS and GDAL,
can you reenable the copy in include until those packagges are fixed?
Radim
