[GRASS5] v.in.ogr: segfaul
Markus Neteler
neteler at itc.it
Sun Feb 12 12:49:15 EST 2006
On Sun, Feb 12, 2006 at 04:32:19PM +0100, Jachym Cepicky wrote:
> hallo,
> I have fresh cvs version of GRASS, and I have problems to import some
> shape, using v.in.ogr:
> (gdb) run
> Starting program: /usr/local/grass-6.1.cvs/bin/v.in.ogr -o dsn=/mnt/mapserver/home/mapserv/krtiny/data/srf.shp out=srf
> [Thread debugging using libthread_db enabled]
> [New Thread -1238561952 (LWP 23475)]
> warning: Lowest section in /usr/lib/libicudata.so.34 is .hash at 00000094
> Program received signal SIGSEGV, Segmentation fault.
> [Switching to Thread -1238561952 (LWP 23475)]
> 0xb7d6a528 in OGRSpatialReference::morphFromESRI () from /usr/lib/libgdal.so.1
> (gdb)
> I use GDAL from Debian package, version 1.2.6
> it worked till now...
> what to do?
Jachym,
please note that 1.2.6 is pretty old:
http://www.gdal.org/dl/
[ ] gdal-1.2.6.tar.gz 13-Mar-2005 23:43 4.1M
[ ] gdal-1.3.0.tar.gz 15-Aug-2005 20:18 6.3M
[ ] gdal-1.3.1.tar.gz 04-Oct-2005 15:08 6.5M
Markus
