[GRASS5] Directed Graph Lib Headers (dglib)
Radim Blazek
radim.blazek at gmail.com
Mon Feb 13 03:31:01 EST 2006
On 2/11/06, Glynn Clements <glynn at gclements.plus.com> wrote:
> Radim Blazek wrote:
> > > > This applies to all header files. We decided to move all GRASS
> > > > header files to include/grass so that they can be installed on system
> > > > (e.g. in /usr/local/include) without conflicts.
> > > > Modules and especially independent applications using GRASS libraries
> > > > (GDAL/OGR, QGIS) should include grass/xxx.h instead of xxx.h.
> > > I've committed a change to use <grass/xxx.h> throughout.
> > Thanks, however include/xxx.h is still used in QGIS and GDAL,
> > can you reenable the copy in include until those packagges are fixed?
> If you add a symlink, e.g.
> ln -s grass /usr/local/grass6/include/grass/grass
> you can just specify /usr/local/grass6/include/grass as the GRASS
> includes directory.
I can, but I am not sure if it is viable also for making packages,
debian e.g.?
Radim
