[GRASS5] r.reclass.area -- new units parameter
Martin Landa
landa.martin at gmail.com
Wed Feb 15 02:54:52 EST 2006
Hi all,
I have tried to modified the GRASS module r.reclass.area. I have added
the new parameter 'units'.
I have also removed part of the code which disallows overwriting base
map (regardless of OVERWRITE variable).
All suggestions are welcomed. Thanks for testing it...
Best regards, Martin
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060215/45db2ccb/r.reclass.area.diff.gz
