[GRASS5] GRASS 6.0.1: Error in startup script: dynamic loading
is not currently available on this syst
Maciek Sieczka
werchowyna at epf.pl
Wed Feb 15 11:34:20 EST 2006
On Wed, 15 Feb 2006 03:54:24 -0800 (PST)
christopher tongco <c_tongco at yahoo.com> wrote:
> Hi, I have been trying to compile Grass 6 for a couple of months now
> and im stuck with this problem while running grass61
> Welcome to GRASS 6.1.cvs (2005)
> GRASS homepage: http://grass.itc.it/
> This version running thru: GNU Bash (Cygwin)
> (/usr/bin/bash.exe) Help is available with the command: g.manual
> -i See the licence terms with: g.version -c
> Start the graphical user interface with: d.m &
> When ready to quit enter: exit
> GRASS 6.1.cvs (spearfish5):~/grass.src/grass-6.0.1 > d.m &
> [1] 2356
> GRASS 6.1.cvs (spearfish5):~/grass.src/grass-6.0.1 > Application
> initialization failed: no display name and no $DISPLAY environment
> variable Error in startup script: dynamic loading is not currently
> available on this syst em
> while executing
> "load /usr/local/lib/tk8.4/../libtk8.4.a Tk"
> ("package ifneeded" script)
> invoked from within
> "package require Tk 8.0"
> invoked from within
> "package require -exact BWidget 1.2.1"
> (file "/usr/local/grass6.1.cvs/etc/dm/d.m.tcl" line 23)
Looks like you don't have tcl/tk installed or Grass doesn't know
where to look for it. I don't know anything about Grass under Cygwin,
but in order to be helped by anybody else you need to specify the
following:
Have you installed tcl/tk? How? How did you install your Grass 6.1 CVS?
Binaries for Cygwin (from where) or built from source? What version
exactly is it (year, month, day).
What operating system?
Hope somebody will give you some guiding once you answer these
questions.
Moreover - your question should be rather sent to grass user list, not
to the devel list.
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
