[GRASS5] Re: [GRASSLIST:10341] i.vpoints can't read temp files
Markus Neteler neteler at itc.it
Thu Feb 16 16:10:24 EST 2006
On Thu, Feb 16, 2006 at 07:02:16PM +0100, Maciek Sieczka wrote:
> On Thu, 16 Feb 2006 14:29:01 -0200
> Carlos "Guâno" Grohmann <carlos.grohmann at gmail.com> wrote:
> > Hello all, I just compile the last wekk CVS, and tried to rectify a
> > raster scanned map with i.vpoints, but when I try to select a vector
> > to be used as reference, it crashes and gives this msg at the bottom
> > of the window: "ERROR: ask_gis_files: can't read tempfile"
> > Any ideas?
> Carlos
> For the record: I confirm the behaviour you describe - I had it on my
> friend's box with Grass 6.1 CVS from mid December 2005.
I have debugged and found the problem - a wrong positioned
G_free() in i.find which is called by i.points and i.vpoints.
It's fixed in 6.1-CVS now.
Markus
