[GRASS5] Re: [bug #4056] (grass) db.test fails on sqlite driver
Markus Neteler neteler at itc.it
Sat Feb 18 12:41:40 EST 2006
On Fri, Feb 17, 2006 at 06:11:02PM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > > select c1 from grass_test1 where d1 < 500 / 2 and i1 <> 2  and c1 ~ 'bc'
> > > DBMI-SQLite driver error:
> > > Error in sqlite3_prepare():select c1 from grass_test1 where d1 < 500 / 2 and
> > > near "~": syntax error
> > > EXECUTE: ******** ERROR ********
> > > '~' is not SQL standard, this is not a bug.
> > I consider it as bug as SQLite supports '~':
> > http://www.sqlite.org/lang_expr.html
> > "Supported unary operators are these:
> Note the use of the word "unary". In the above select statement, the ~
> is being used as a /binary/ operator, which SQLite doesn't support:
>   SQLite understands the following binary operators, in order from
>   highest to lowest precedence:
>       =    ==   !=   <>   IN
>       AND
>       OR
Ah, I see - but what does it mean for db.test?
Add a sqlite test to skip it?
Markus
