[GRASS5] Re: NVIZ and 'bg'/'fg' commands: stalled
Bob Covill
bcovill at tekmap.ns.ca
Sun Feb 19 18:57:45 EST 2006
Hi Markus,
This behavior is probably because nviz is a reworked wish executable.
This results in odd behavior such as running it in the background, etc.
Probably the best way around this is to go back to using a shell script
to start nviz. I had briefly looked into this a while back but had not
completely gotten around some of the command line argument issues.
Bob
On Mon, 2006-02-20 at 00:47 +0100, Markus Neteler wrote:
> On Mon, Feb 20, 2006 at 12:44:12AM +0100, Markus Neteler wrote:
> > Hi,
> > when sending NVIZ to background on Linux, it get's
> > stuck - I cannot even 'fg' it. Where should I look
> > for the problem?
> Funny: pressing 'return' in the terminal helps and
> the wish prompt appears. Then it works again.
> Any ideas?
> Markus
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
