[GRASS5] r.terraflow failure
endeitz
endeitz at yahoo.com
Mon Feb 20 11:24:13 EST 2006
Just a followup to my previous message. Instead of using the snapshot binary
I compiled GRASS myself. This apparently fixed the 2GB issue. However,
r.terraflow is still crashing on what appears to be a seek error of some
kind on a file of approximately 7GB (again, is it a file size limit?). I
was wondering if anyone could give me a clue. The error is near the end of
the listing below. I also show ulimit results below, if that is relevant.
GRASS 6.1.cvs (lcra):~/grassdata > ulimit -a
core file size (blocks, -c) 1000000
data seg size (kbytes, -d) unlimited
file size (blocks, -f) unlimited
max locked memory (kbytes, -l) unlimited
max memory size (kbytes, -m) unlimited
open files (-n) 1024
pipe size (512 bytes, -p) 8
stack size (kbytes, -s) 8192
cpu time (seconds, -t) unlimited
max user processes (-u) 3071
virtual memory (kbytes, -v) unlimited
r.terraflow December 2003
region size is 13458 x 13438
cell elev15000 header compatible with region header
elevation stored as FLOAT (4B)
STREAM temporary files in /var/tmp (THESE INTERMEDIATE STREAMS WILL NOT BE
DELETED IN CASE OF ABNORMAL TERM
file stats.out exists - renaming.
reading data from elev15000 to stream /var/tmp/STREAM_djueQG:
total elements=180848604, nodata elements=0
largest temporary files:
FILL: 9.43G (10127521824) [180848604 elements, 56B each]
FLOW: 13.47G (14467888320) [180848604 elements, 80B each]
Will need at least 26.95G (28935776640) space available in /var/tmp
MM warning: limit=314572800B. allocating 157138456B. limit exceeded by
17722B.
17753B.
17784B.
17815B.
17846B.
17718B.
17749B.
17780B.
17811B.
MM warning: limit=314572800B. allocating 157015336B. limit exceeded by
17718B.
17749B.
17749B.
17780B.
17811B.
MM warning: limit=314572800B. allocating 157220512B. limit exceeded by
14518B.
14549B.
14580B.
14611B.
14642B.
14673B.
r.terraflow: 3scan.h:163: void scan3line(FUN&, AMI_STREAM<T>*,
AMI_STREAM<T>*, AMI_STREAM<T>*, BASETYPE, short int) [with T =
waterGridType, BASETYPE = waterWindowBaseType, FUN = waterWindower]:
Assertion `ae == AMI_ERROR_END_OF_STREAM' failed.
GRASS 6.1.cvs (lcra):~/grassdata > ls -lh /var/tmp
total 11G
-rw------- 1 nedeeds nedeeds 690M Feb 18 16:29 STREAM_a5xEvs
-rw------- 1 nedeeds nedeeds 7.0G Feb 18 17:14 STREAM_LjcOQz
-rw------- 1 nedeeds nedeeds 2.7G Feb 18 16:59 STREAM_TtzchB
View this message in context: http://www.nabble.com/Re%3A-GRASSLIST%3A7448-Re%3A-r.terraflow-failured-t130887.html#a3033415
Sent from the Grass5 - Dev forum at Nabble.com.
