[GRASS5] r.terraflow failure
Tue Feb 21 17:17:32 EST 2006
endeitz wrote:
> Where would I put the flag to compile with debugging symbols on?  Would it
> suffice to just put it in the Makefile in the r.terraflow directory, or does
> it have to appear higher up the tree?
Debugging symbols should be enabled by default. If you're doing
extensive debugging, you probably want to disable optimisation, so
either run configure as:
	CXXFLAGS=-g ./configure ...
or build with:
	make CXXFLAGS1=-g
