[GRASS5] d.m and d.mon fail after cvs update
Kirk R. Wythers kwythers at umn.edu
Wed Feb 22 11:25:19 EST 2006
I just cvs updated (20060222)and can no longer start d.m or d.mon.
d.m fails with:
GRASS 6.1.cvs (minnesota_utm):~ > gis.m
Error in startup script: couldn't open "/usr/local/grass-6.1.cvs/etc/
gm/pointer.gif": no such file or directory
     while executing
"image create photo -file "$gmpath/pointer.gif""
     (procedure "MapToolBar::create" line 33)
     invoked from within
"MapToolBar::create $map_tb"
     (procedure "MapCanvas::create" line 47)
     invoked from within
"MapCanvas::create"
     (procedure "Gm::startmon" line 11)
     invoked from within
"Gm::startmon"
     (procedure "Gm::create" line 96)
     invoked from within
"Gm::create"
     (procedure "main" line 29)
     invoked from within
"main $argc $argv"
     (file "/usr/local/grass-6.1.cvs/etc/gm/gm.tcl" line 777)
and d.mon x0 fails with:
GRASS 6.1.cvs (minnesota_utm):~ > d.mon x0
Problem selecting x0. Will try once more
Any thoughts?
Kirk
