[GRASS5] d.m and d.mon fail after cvs update
Fri Feb 24 06:56:13 EST 2006
Michael Barton wrote:
> Currently when I use monitor override, I cannot open an xmon window from the
> GIS Manager. I get a 'No socket to connect to for monitor <x0>' error.
> The way I had it was ...
> d.mon start=gism -s
> set env(MONITOR_OVERRIDE) "gism"
> ...display commands
> d.mon stop=gism
> If I try to start an xmon (e.g., for v.digit), I get the 'No socket...'
> error.
> If I change to...
> d.mon start=gism
> ...display commands
> d.mon stop=gism
> I get no error.
You need to unset MONITOR_OVERRIDE after you're done with it, i.e.:
	unset env(MONITOR_OVERRIDE)
> I've tried using monitor override to select the xmon for v.digit (or other
> module that needs it) and unsetting monitor override after stopping gism.
Either of those should work.
> This is not a big issue now. But when I start redoing the compositing, I'll
> want to keep gism running all the time, except when doing a window resize.
> Then I'll really need to use monitor override.
You can set and unset env(MONITOR_OVERRIDE) while the gism monitor is
running. It only needs to be set while running d.* commands which are
supposed to use a specific monitor.
