[GRASS5] Swig interface for Grass
Markus Neteler neteler at itc.it
Mon Jan 2 03:15:44 EST 2006
Hello Sajith,
sorry for the delay.
Unfortunately I don't know much about SWIG. My suggestion
is to study how things are done in GDAL. I can see that there
are all typemaps in
 gdal/swig/include/
Maybe we should try the same?
Probably I should launch a "call for help" in the
FreeGIS mailing list to find someone to help?
Markus
On Sun, Dec 25, 2005 at 12:43:32PM +0530, Sajith VK wrote:
> Hello all,
> I was going through the perl-grass interface(swing)
> and to do the same for python.
> Since I am not good in "make and perl" I find difficulty in
> modifying the Makefile needed.
> So here I am attaching my "typemaps" for python-grass.
> Can someone suggest how to develop the Makefile for this?
> Change the rules, or the rules will change you
>      ---------Kumaranasan
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
