[GRASS5] Makefile problem - Re: [GRASS-announce] GRASS 6.0.2RC3 released
Markus Neteler neteler at itc.it
Tue Jan 3 14:13:57 EST 2006
On Tue, Jan 03, 2006 at 05:13:44PM +0000, Glynn Clements wrote:
> > >     * bugfix for 'builddemolocation target' in Makefile
> > >       when building as root (RPMs etc)
> > Unfortunately I still have the following problem:
> > [root at bild-mandriva2006 dist.i686-pc-linux-gnu]# ls -l dist.i686-pc-linux-gnu/
> > insgesamt 40
> > drwxr-sr-x   3 1338  204 4096 Jan  3 14:21 demolocation/
> > drwxr-xr-x   3 root root 4096 Jan  3 14:22 docs/
> > drwxr-xr-x   4 root root 4096 Jan  3 14:22 bwidget/
> > drwxr-xr-x   2 root root 4096 Jan  3 14:22 fonts/
> > Although 'tar' is used in the 'builddemolocation' target in the
> > main Makefile, the owner is still preserved (1338 above).
> > It must be the owner compiling GRASS (here, root), otherwise the
> > virtual session to generate the HTML manuals fails.
> > Any ideas?
>        -o, --no-same-owner
>               do not attempt to restore ownership when extracting; -o exhibits
>               this behavior when extracting an archive
would you mind to apply it to CVS? I don't get it
working (maybe order of parameters or whatever).
Thanks
 Markus
