[GRASS5] Makefile problem - Re: [GRASS-announce] GRASS 6.0.2RC3 released
Glynn Clements
glynn at gclements.plus.com
Wed Jan 4 11:38:03 EST 2006
> > > > * bugfix for 'builddemolocation target' in Makefile
> > > > when building as root (RPMs etc)
> > > Unfortunately I still have the following problem:
> > > [root at bild-mandriva2006 dist.i686-pc-linux-gnu]# ls -l dist.i686-pc-linux-gnu/
> > > insgesamt 40
> > > drwxr-sr-x 3 1338 204 4096 Jan 3 14:21 demolocation/
> > > drwxr-xr-x 3 root root 4096 Jan 3 14:22 docs/
> > > drwxr-xr-x 4 root root 4096 Jan 3 14:22 bwidget/
> > > drwxr-xr-x 2 root root 4096 Jan 3 14:22 fonts/
> > > Although 'tar' is used in the 'builddemolocation' target in the
> > > main Makefile, the owner is still preserved (1338 above).
> > > It must be the owner compiling GRASS (here, root), otherwise the
> > > virtual session to generate the HTML manuals fails.
> > > Any ideas?
> > -o, --no-same-owner
> > do not attempt to restore ownership when extracting; -o exhibits
> > this behavior when extracting an archive
> would you mind to apply it to CVS? I don't get it
> working (maybe order of parameters or whatever).
Done.
Someone on a system whose tar isn't GNU tar should check it for
compatibility.
