[GRASS5] Makefile problem - Re: [GRASS-announce] GRASS 6.0.2RC3 released
Markus Neteler
neteler at itc.it
Wed Jan 4 11:47:52 EST 2006
On Wed, Jan 04, 2006 at 04:38:03PM +0000, Glynn Clements wrote:
> > > > > * bugfix for 'builddemolocation target' in Makefile
> > > > > when building as root (RPMs etc)
> > > > Unfortunately I still have the following problem:
> > > > [root at bild-mandriva2006 dist.i686-pc-linux-gnu]# ls -l dist.i686-pc-linux-gnu/
> > > > insgesamt 40
> > > > drwxr-sr-x 3 1338 204 4096 Jan 3 14:21 demolocation/
> > > > drwxr-xr-x 3 root root 4096 Jan 3 14:22 docs/
> > > > drwxr-xr-x 4 root root 4096 Jan 3 14:22 bwidget/
> > > > drwxr-xr-x 2 root root 4096 Jan 3 14:22 fonts/
> > > > Although 'tar' is used in the 'builddemolocation' target in the
> > > > main Makefile, the owner is still preserved (1338 above).
> > > > It must be the owner compiling GRASS (here, root), otherwise the
> > > > virtual session to generate the HTML manuals fails.
> > > > Any ideas?
> > > -o, --no-same-owner
> > > do not attempt to restore ownership when extracting; -o exhibits
> > > this behavior when extracting an archive
> > would you mind to apply it to CVS? I don't get it
> > working (maybe order of parameters or whatever).
> Done.
Thanks, also done for GRASS 6.0-CVS (for RC4 or final).
> Someone on a system whose tar isn't GNU tar should check it for
> compatibility.
Right.
Markus
