[GRASS5] zlib compression for CELL maps
Jaro Hofierka hofierka at geomodel.sk
Wed Jan 4 09:44:35 EST 2006
Hello,
I have a problem with a size of integer (CELL) maps. It is strange that
the size of compressed integer maps is bigger than the same maps in
floats. Recently, we tried to import srtm files and floating point maps
took much less disk space then integers :-(
I tried to use the GRASS_INT_ZLIB variable, but the compression flag in
a header file is still set to 1 (should be 2?). Problably I missed
something. I re-compiled GRASS using zlib.
Many thanks for any hints!
Jaro
