[GRASS5] Rename of development mailing list?
Wed Jan 4 10:25:15 EST 2006
Wolf Bergenheim wrote:
> > since the name of this mailing list 'grass5' seems to become
> > inappropriate, I suggest a renaming of development mailing list
> > to
> >  grass-dev at grass.itc.it
> > I can define an alias to keep the current grass5 at grass.itc.it
> > address working.
> I wondered about that, when I first signed up. At first I thought grass5
> was some old dev list (; IMO a good change. Also while you are at it,
> perhaps make the list add a reply-to header that points back to the
> list? Was this already discussed earlier and you want it not to
> auto-reply to the list? In that case forget about my question (;
It's been discussed in the past.
In short, the Reply-To header "belongs" to the sender. It's meant for
the case when the sender doesn't want personal replies to go to their
