[GRASS5] zlib compression for CELL maps
Jaro Hofierka hofierka at geomodel.sk
Wed Jan 4 13:15:54 EST 2006
Glynn Clements wrote:
> Jaro Hofierka wrote:
>>Recently, we tried to import srtm files and floating point maps
>>took much less disk space then integers :-(
>>I tried to use the GRASS_INT_ZLIB variable, but the compression flag in
>>a header file is still set to 1 (should be 2?). Problably I missed
>>something.
> Did you export it, e.g.:
> 	GRASS_INT_ZLIB=1
> 	export GRASS_INT_ZLIB
> or (bash-specific):
> 	export GRASS_INT_ZLIB=1
I did it using g.gisenv set="GRASS_INT_ZLIB=1"
Then I checked using g.gisenv get=GRASS_INT_ZLIB.
Jaro
