[GRASS5] zlib compression for CELL maps
Wed Jan 4 13:10:51 EST 2006
Jaro Hofierka wrote:
> I have a problem with a size of integer (CELL) maps. It is strange that
> the size of compressed integer maps is bigger than the same maps in
> floats.
FP maps use zlib; integer maps use run-length encoding.
> Recently, we tried to import srtm files and floating point maps
> took much less disk space then integers :-(
> I tried to use the GRASS_INT_ZLIB variable, but the compression flag in
> a header file is still set to 1 (should be 2?). Problably I missed
> something.
Did you export it, e.g.:
	GRASS_INT_ZLIB=1
	export GRASS_INT_ZLIB
or (bash-specific):
	export GRASS_INT_ZLIB=1
