[GRASS5] errors building today's NVIZ
Maciek Sieczka werchowyna at epf.pl
Sat Jan 7 15:32:45 EST 2006
On pią, 2006-01-06 at 23:38 +0100, Markus Neteler wrote:
> On Fri, Jan 06, 2006 at 10:31:34PM +0100, Maciek Sieczka wrote:
> > Bob, All,
> > Building today'd Grass 6.1 CVS I have following error whwn compling
> > NVIZ:
<snip>
> > The last succesfull Grass 6.1 CVS build on my machine was 2005-11-16.
> Maciek,
> using google I found this one:
>  http://vtk.org/Bug/bug.php?op=show&bugid=1777&pos=0
> "VTK build failed due to:
> bin/libvtkRendering.so: undefined reference to `XF86VidModeQueryVersion'
> bin/libvtkRendering.so: undefined reference to `XF86VidModeGetModeLine'
> Those symbols are defined in
> /usr/X11R6/lib/libXxf86vm.so.1
> Problem #1:
> There is no: /usr/X11R6/lib/libXxf86vm.so
> Problem #2:
> We need to setup proper dependency
> Posted by: ******
> Date: 11:19 AM 04-18-2005
> Need a special package for that:
> sudo apt-get install libxxf86vm-dev
> Posted by: ******
> Date: 3:16 AM 04-24-2005
> Also Assign:
> /usr/X11R6/lib/libXext.so;/usr/X11R6/lib/libXxf86vm.so
> as the new value to the variable: X11_Xext_LIB
> Maybe it helps?
Markus,
Thanks. Unfortunatelly this doesn't help. I've already had
libxxf86vm-dev installed when compilation errors in NVIZ poped up.
See:
maciek at sorbus:~$ sudo apt-get install libxxf86vm-dev
Password:
Reading package lists... Done
Building dependency tree... Done
libxxf86vm-dev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Maciek
W polskim Internecie są setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
