[GRASS5] errors building today's NVIZ
Markus Neteler
neteler at itc.it
Sat Jan 7 15:36:47 EST 2006
On Sat, Jan 07, 2006 at 09:32:45PM +0100, Maciek Sieczka wrote:
> On pi?, 2006-01-06 at 23:38 +0100, Markus Neteler wrote:
> > On Fri, Jan 06, 2006 at 10:31:34PM +0100, Maciek Sieczka wrote:
> > > Bob, All,
> > > Building today'd Grass 6.1 CVS I have following error whwn compling
> > > NVIZ:
> <snip>
> > > The last succesfull Grass 6.1 CVS build on my machine was 2005-11-16.
> > Maciek,
> > using google I found this one:
> > http://vtk.org/Bug/bug.php?op=show&bugid=1777&pos=0
> > "VTK build failed due to:
> > bin/libvtkRendering.so: undefined reference to `XF86VidModeQueryVersion'
> > bin/libvtkRendering.so: undefined reference to `XF86VidModeGetModeLine'
> > Those symbols are defined in
> > /usr/X11R6/lib/libXxf86vm.so.1
> > Problem #1:
> > There is no: /usr/X11R6/lib/libXxf86vm.so
> > Problem #2:
> > We need to setup proper dependency
> > Posted by: ******
> > Date: 11:19 AM 04-18-2005
> > Need a special package for that:
> > sudo apt-get install libxxf86vm-dev
> > Posted by: ******
> > Date: 3:16 AM 04-24-2005
> > Also Assign:
> > /usr/X11R6/lib/libXext.so;/usr/X11R6/lib/libXxf86vm.so
> > as the new value to the variable: X11_Xext_LIB
> > Maybe it helps?
> Markus,
> Thanks. Unfortunatelly this doesn't help. I've already had
> libxxf86vm-dev installed when compilation errors in NVIZ poped up.
> See:
> maciek at sorbus:~$ sudo apt-get install libxxf86vm-dev
> Password:
> Reading package lists... Done
> Building dependency tree... Done
> libxxf86vm-dev is already the newest version.
> 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Did you also try the other trick suggested there?
It seems to be a distro problem.
Markus
